Transaxle potential speed sensor problem?
1998 SATURN SL2
120,000 MILES • 2WD • AUTOMATIC
CONNARD58
  • 7 POSTS
Service Engine light is on and intermittently car rpm revs higher and car lurches forward briefly when slowing down to a stop, sluggish acceleration from stop and hard banging into reverse. Possible input or output speed sensor problem? Not a mechanic so I can't scan for codes. Thanks.
Jun 25, 2023 at 5:50 AM
It is easy to scan for code which is a must to fix this problem after checking the level of the transmission fluid, these guides can help us:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
and
Please go over these guides and get back to us.
Jun 25, 2023 at 3:08 PM
CONNARD58
  • 7 POSTS
Okay, thanks. The fluid level is okay, and filter is newish. Will get a scanner and follow the guides to get the codes. Will report back with results.
Jun 25, 2023 at 7:51 PM
Sounds good.
Jun 26, 2023 at 12:10 PM
CONNARD58
  • 7 POSTS
FYI, waiting for my scanner to arrive after ordering online. Probably next week. Happy Fourth!
Jun 30, 2023 at 7:33 AM
Good job, let me know happy 4th of July!
Jul 1, 2023 at 11:09 AM
CONNARD58
  • 7 POSTS
Okay, here are the codes before erasing them which by the way turned off the check engine light and surprisingly so far has returned the Transmission to normal operation although I haven't driven much. Just FYI.
Jul 11, 2023 at 12:09 AM
CONNARD58
  • 7 POSTS
Transmission sensor code is back and problem with transmission back. Any advice?
Jul 11, 2023 at 7:05 AM
CONNARD58
  • 7 POSTS
Okay, I discovered the black/white ground wire was disconnected from the sensor. I reconnected and it ran fine for a bit then failed again to same problem. Now a funny noise is coming from the sensor when the engine is running. Maybe it's shot?
Jul 11, 2023 at 10:03 AM
CONNARD58
  • 7 POSTS
Okay, classic amateur mistake. Attached the ground to wrong terminal. Got it right and she runs like new. My old warhorse is back in business. Thanks for the scanner tip you saved me a bundle! Cheers!
Jul 11, 2023 at 10:33 AM
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Jul 13, 2023 at 9:00 AM
