i noticed the daytime running light dashboard indicator flashing at me when i placed the car into gear. it comes on normal, then shortly afterwards flashes 7 or 8 times, pauses, then does it again a couple times, then shuts off. i found the right side hi beam not functioning in the daytime running lights function as well as during the normal hi beam operation. i've tested the bulbs and all is ok there. i did find an almost broken blue wire on the right side hi beam lead right near the plug to interface with the bulb, i striped that back a little and soldered and shrink wraped it up proper but still no 12 volts continuing back from bulb.. i checked the fuses for that side and all is ok with them. as a last ditch effort as i could not get any information to otherwise confirm or deny my assumption i replaced the daytime running lights module/relay.. still no right side hi beam nor running lights.. could there still be a broken wire in that circuit.. i guess i'd have to tear the harness and fuse/relay center apart enough to get to the other end of those leads to check i suppose.. any help will be most graciously appreciated..
Apr 8, 2010 at 7:34 PM
