2001 Saturn SL2 Plastic valve cover replacement.
2001 SATURN SL2
71,000 MILES • 4 CYL • FWD • AUTOMATIC
SHYANNROSE
  • 8 POSTS
Does anyone know where i can find the plastic valve cover for this car?? My motor mount bolts cracked and the washers made holes in it causing an oil leak... I have epoxy over it for now and it hasnt leaked but i am afraid it may start to leak again.
Thanx!!!
Jun 26, 2010 at 9:16 AM
SATURNTECH9
  • 30,869 POSTS
I would try getting one at a pick a part or junk yard.Also there shouldn't be any washer's holding in your upper mount.There is just stud's and nut's get the correct stud's and nut's from where you get the valve cover.
Jun 26, 2010 at 10:56 AM
SHYANNROSE
  • 8 POSTS
Yea thats what i kinda figured... thanx. some genius before i owned the car stripped out all the holes so i had to drill out and re tap the holes and it didnt have the studs in it already... thank you!!!
Jun 26, 2010 at 1:59 PM
