2001 Saturn SL2 cruise control
2001 SATURN SL2
126,000 MILES • 4 CYL • FWD • AUTOMATIC
RONCAM47390
  • 8 POSTS
Is it possible to put cruise control from a 1995sw2 saturn onto a 2001 SL2 with out to much trouble and would it work ?----Ron
Mar 12, 2010 at 2:19 PM
SATURNTECH9
  • 30,869 POSTS
[quote:e599f156aa="roncam47390"]Electrical problem
2001 Saturn SL2 4 cyl Front Wheel Drive Automatic 126000 miles
Is it possible to put cruise control from a 1995sw2 saturn onto a 2001 SL2 with out to much trouble and would it work ?----Ron[/quote:e599f156aa]
first of all thank u for the donation it really helps us to be able to answer everyones questions.as far as going from a 1995 to 2002 i dont belive it would be a good fit.for starters the switch for the cruise is differnt ur 1995 is on the edge of ur steering wheel cover.in 2000 they changed that to a differnt switch in towards the air bag.as far as the cruise module iam not sure if that changed as well.i used to add cruise control to the 1991-1999 ones for people that bought cars and wanted to add cruise to there cars.on the early saturns u had to change the air bag coils then the newer ones i belive 1995 and up with or without factory cruise they starting putting the cruise switch connectors on the all the air bag coils made it alot easier to add cruise.if u wanted to add cruise to ur car i would go to pick apart and find a 2000-2002 saturn s model to get it from.hope this helps.
Mar 12, 2010 at 2:46 PM
