2000 Saturn SL2 GAS LINE
2000 SATURN SL2
150,000 MILES • 6 CYL • AWD • AUTOMATIC
SHDOW03
I RAN OUT OF GAS AND KNOW IT HAS A FULL TANK AND WILL NOT START PUMP IS WORKING FINE AND GAS IS COMING OUT OF THE FUEL FILTER OK.
Nov 8, 2010 at 4:28 PM
SHDOW03
[quote:09efc18223="SHDOW03"]Engine Performance problem
2000 Saturn SL2 6 cyl All Wheel Drive Automatic 150000 miles
I RAN OUT OF GAS AND KNOW IT HAS A FULL TANK AND WILL NOT START PUMP IS WORKING FINE AND GAS IS COMING OUT OF THE FUEL FILTER OK.[/quote:09efc18223]
Nov 8, 2010 at 4:29 PM
SATURNTECH9
  • 30,869 POSTS
So it was running fine till you ran out of gas and now it crank's and won't start since you filled up the gas tank?Have you ever changed the fuel filter on the car they get changed ever 100,000 mile's and by that time there really restricted.Also you say the gas flow's thru the fuel filter that doesn't mean that you have enough pressure for the engine to start and run.I need to know what your fuel pressure is at the fuel rail.Also do you have spark?
Nov 8, 2010 at 4:37 PM
