1999 Saturn SL2 ignition switch
1999 SATURN SL2
72,000 MILES • 4 CYL • FWD • AUTOMATIC
HALLER55
the ignitioin switch is loose in the steering collum. How can I tighten it?
Apr 15, 2010 at 12:21 PM
SATURNTECH9
  • 30,869 POSTS
[quote:9b2d68ea13="haller55"]Steering problem
1999 Saturn SL2 4 cyl Front Wheel Drive Automatic 72000 miles
the ignitioin switch is loose in the steering collum. How can I tighten it?[/quote:9b2d68ea13]
u can replace the ignition housing or just try replacing the shear bolts that hold it on which doesnt always work.let me know which way u would like to try and ill help u out with info on that.
Apr 15, 2010 at 12:45 PM
HALLER55
I's like to just replace the shear bolts, can I do this myself? How?
Apr 15, 2010 at 2:48 PM
SATURNTECH9
  • 30,869 POSTS
[quote:dfa514149d="haller55"]I's like to just replace the shear bolts, can I do this myself? How?[/quote:dfa514149d]
u can replace the bolts urself its not real easy though u have to remove the coulmn shrouds and igniton cyclinder get a thin long round punch with a sharp tip and u have to bite into the bolts head at differnt points and unscrew like that untill u can grab it with pliers to finsh unscrew it all the way then put the new screws in with a small reverse torx socket or inverted torx.sound like something u want to tackle?
Apr 16, 2010 at 2:10 PM
HALLER55
Thank you very much, Louie
Apr 16, 2010 at 3:48 PM
