1999 Saturn SL2 DTCP0171
1999 SATURN SL2
68,775 MILES • 4 CYL • 2WD • AUTOMATIC
REPLACED FUEL FILTER - FUEL PRESSURE AT 52PSI RUNNING REPLACED SPARK PLUGS & WIRES VALVE COVER GASKETS - CAR CAME BACK WITH P0171 - P0341 - P1599 - P1620 & P0507 - FOUND DEFECTIVE PRESSURE REGULATOR IN PUROLATOR FILTER - REPLACED WITH WIX FILTER & CLEARED CODES - PUT THROUGH DRIVE CYCLE & P0171 CAME BACK CAN NOT FIND ANY VACUUM LEAKS ANY IDEAS?
Aug 2, 2010 at 10:08 PM
SATURNTECH9
  • 30,869 POSTS
https://www.2carpros.com/forum/automotive_pictures/416332_1999_SL2_P0171_1.jpg
With the P0507 code and P0171 code i would say your looking for a vacuum leak especially since you already have the fuel pressure squared away.
Aug 3, 2010 at 2:06 PM
