1999 Saturn SL2 Drive Belt Tensioner
1999 SATURN SL2
95,000 MILES • 4 CYL • FWD • AUTOMATIC
KMCGINLEY
  • 14 POSTS
I had the belt replaced about 6K ago and unfortunately had a neighborhood joe do the labor, resulting in the threads on the tensioner bolt to get ripped. Because the bolt was seated incorrectly, it was vibrating, causing a pinging sound. The sound went away, however, I guess because it "settled" into a certain spot within the bolt. Now it's pinging again whenever the engine is running, and louder when the A/C is on. I'm wondering if just the bolt can be replaced or if the whole tensioner unit has to be replaced, which would probably mean taking the belt off and putting it back on?
Aug 24, 2010 at 9:36 AM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.So your talking about the center bolt that hold's the pulley on right?If so is it not screwed all the way in tight against the pulley's center bearing?Causing the pulley to move around?
Aug 24, 2010 at 11:54 AM
KMCGINLEY
  • 14 POSTS
Yes that's the bolt but I don't think the pulley is moving around-just the bolt is not tight, causing it to vibrate-if the bolt threads are bad, does that mean that the piece it's screwing into has to be replaced too? Probably, huh..
Aug 24, 2010 at 11:28 PM
SATURNTECH9
  • 30,869 POSTS
If the tensioner is moved sometimes when you replace the belt and it was weak that could cause the tensioner to let go all the way.But yes if the bolt's thread's are damaged you will have to replace the housing.If you replace the tensioner i would get a dayco brand one alot of the aftermarket one's i have found rattle.
Aug 25, 2010 at 1:37 PM
