1999 Saturn SL2 Burning Oil/Check engine light is on
1999 SATURN SL2
DMGREEN1
Engine Performance problem
1999 Saturn SL2 4 cyl Automatic 89,980 miles
I bought this car at 81,000 miles. It is burning about 2-3 quarts a week. It no has 89,980 miles on it. I was wondering how much it would cost to fix this problem. Also the check engine light is on. Any idea on what that could be?
Feb 16, 2010 at 2:21 PM
SATURNTECH9
  • 30,869 POSTS
[quote:33658cd0f3="dmgreen1"]Engine Performance problem
I bought this car at 81,000 miles. It is burning about 2-3 quarts a week. It no has 89,980 miles on it. I was wondering how much it would cost to fix this problem. Also the check engine light is on. Any idea on what that could be?[/quote:33658cd0f3]
u need to replace ur engine with that much oil use that will cost alot well over 1,000 labor and like 2200 for the engine u could probably shop around for the engine maybe find a good used one.u could try adding a qt of lucas oil treatment that helps to slow the burning down.in ur case i would get the gallon bottle of lucas its alot cheaper u just have to measure out a quart which isnt a big deal.as far as ur light goes if u can get me the codes it has i can help u out there.let me know.
Feb 16, 2010 at 2:29 PM
DMGREEN1
Thanks for your response. After hearing that, I think I may just try to get rid of it because it may not be worth it to spend that much money on fixing it. Thanks again!
Feb 16, 2010 at 11:20 PM
