1999 Saturn SL2 Bad Gas Mileage 12 miles per gallon
1999 SATURN SL2
84,450 MILES • 4 CYL • 2WD • AUTOMATIC
MGG4591
My car is getting 12 mpg both highway and city average. I don't hot rod it, and i warm it up in the winter before i bring it out. This mileage is consistent for both the winter and summer. I calculate my mileage by miles driven/gallons used.
I have no clue what is wrong. I brought it to the GM dealer and they said the car runs perfect.
Here is a list of everything i replaced:
Battery
Air Filter
EGR Valve
PCV Valve
NGK Plugs and Wires
Control Module
Starter
WIX #33731 Fuel Filter/Regulator
ECTS and Connector
AIT Sensor and Connector
MAP Sensor
Front Manifold Oxygen Sensor, OEM
Thermostat
Valve Cover Gasket
Cleaned the Throttle Body
Feb 3, 2010 at 12:59 AM
TAYLORDOEGE
i noticed your list and one thing that comes to mind would be your coolant temp sensor. its an 8 dollar part and is easy to replace. it is located on the driver side part of the engine, just in arms reach on the side of the engine block.
Feb 9, 2010 at 10:33 PM
SERVICE WRITER
  • 9,123 POSTS
I'll second that on the ECT...very common on those.
https://www.2carpros.com/forum/gas-mileage-tips-vt135422.html
Feb 11, 2010 at 1:38 PM
