1999 Saturn SL2
1999 SATURN SL2
BERRY56BLUE
Engine Mechanical problem
1999 Saturn SL2 Automatic
How do i remove the harmonic balancer bolt from a 1.9L 1999 Saturn SL2? Does it require a special tool?
Thanks,
Grace
May 9, 2009 at 10:55 AM
LEGITIMATE007
  • 5,121 POSTS
yes, it is best to use a air impact gun, because it may be really hard to "crack" the bolt and at the same time the shaft will want to turn. once you take the bolt off , you will most likely need a puller, pretty inexpensive, you can get one from your local parts place.
May 9, 2009 at 11:13 AM
