check the fuse #1 (green, 30 amp) in the underhood fuse block, fuse may be labeled PWR CONVCE
you would have to remove door panel and disconnect the motor and regulator assembly from the window glass before manually lifting glass up.
Jul 7, 2010 at 6:03 PM
