1997 Saturn SL2 switch
1997 SATURN SL2
BJM0740
1997 Saturn SL2
My key is stuck in the iginion switch between off and on and will not move either way and I cannot get it out of the switch. What do I do?
If I replace the switch will the air bag have to be moved too? Will this destroy the airbag?
Thank you
Jean McIntosh
Sep 25, 2010 at 7:13 PM
SATURNTECH9
  • 30,869 POSTS
Is it stuck in acc position?
Sep 25, 2010 at 8:01 PM
BJM0740
I think it is in the ACC or Auxillary poisition. It is in the position before the lock position.
Sep 25, 2010 at 8:20 PM
SATURNTECH9
  • 30,869 POSTS
There is two 5.5mm screw's one on each side on the under side of the steering column cover's you will need a nut driver to take them out.There the deeper to get at screw's then the other three.Take those out and pop the the upper cover off now unplug the connectors above the cylinder.Then look above the ignition cylinder you will see a square button push the button in then pull the cylinder out.Then you can see if the cylinder turn's out of the housing.Let me know what you find.
Sep 25, 2010 at 8:35 PM
