1997 Saturn SL2 Horn troubles
1997 SATURN SL2
90,000 MILES • 4 CYL • FWD • AUTOMATIC
JODY512
My horn on my Saturn SL2 has stopped working. We have checked the fuses and still to no avail, the horn is silent. I first noticed the problem when using my automatic lock remote. The horn used to sound when I locked the car, then all of a sudden, it stopped. It still is not working. Any suggestions for a fix?
Feb 10, 2009 at 12:54 PM
JDL
  • 16,098 POSTS
Did you check that the fuse circuit is hot all the time, for the horn? The circuit that goes up in the steering column for the horn is just a ground, I believe.
If there is a clock-spring in the steering column, that can cause a problem, sometimes.
Feb 10, 2009 at 1:15 PM
