1997 Saturn SL2 codes
1997 SATURN SL2
RASHTON
Transmission problem
1997 Saturn SL2 4 cyl Automatic
when these codes show up p0734 and p0733 what is the solution to fix it.
Sep 21, 2009 at 9:00 PM
SATURNTECH9
  • 30,869 POSTS
those codes p0733 no third gear and p0734 no fourth gear.it code be the third gear and fourth gear pistons not holding pressure to hold the gears in place.or it could be a electricial problem but what i have seen most of the time is low transmission pressure and when u get into the higher gears like third and fourth it takes more pressure to hold the gears because they are a higher gear ratio.what usually casues this problem is the transmission pressure regulator which is in the valvebody of the transmission which u have to buy the whole valvebody.an expensive repair.good luck let me know how it goes.
louie
Oct 2, 2009 at 8:06 PM
