1996 Saturn SL2 Turn signal switch and hazard lights
1996 SATURN SL2
100,000 MILES • 4 CYL • 2WD • MANUAL
TABBY1
My 1996 saturn SL2 turn signal switch does not work. I am not able to signal when I turn left or right MY hazard lights do not work either. My brake light on the drivers side works intermittently, what may the problem(s) be? How do I fix the problem(s)?
Aug 3, 2010 at 10:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
seeing as how the brake lights, turn signals and hazard lights all run through the turn signal switch itself, I would say the switch is needing replaced.
Aug 4, 2010 at 12:52 AM
TABBY1
My horn does not work as well, could it need a new fuse?
Aug 4, 2010 at 9:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
fuses are always first place to check, if fuses are good check horn relay.
Aug 4, 2010 at 6:51 PM
