Hello;
Back in May, the low coolant warning light came on and I noticed that the radiator had a crack in it along a seam. So I then replaced the radiator with a new one.
Now it is July and the radiator has again sprung a leak. I don't wish to replace the radiator again if it will just burst again due to underlying problem. Is there something I should look for before replacing?
Sincerely;
Michelle
PS: The engine burns a little oil. Also the coolant sensor (it had a crack in it) and the thermostat was replaced a few months before the radiator. The pressure relief cap was replaced at the same time as the radiator.
Sincerely;
Michelle
Jul 6, 2010 at 1:07 AM
