I am having problems with my 1996 Saturn SL2. Yesterday the temperature gauges and fan quit working (unless AC was on). Found a ground wire loose so plugged in fans. Temperature Gauge still not working. I changed the Coolant Temp Sensor and still not fixed. Not for sure what the problem is. Also, my car has a really high idle when I start it which is normal but when I am at stop lights or slowing down, I lose my RPM's and it almost dies unless I drop it in neutral and give it some gas. I have replaced the Coolant Temperature Sensor but I bought it from O'Reilly's. Should I get one from the dealer? What else could be the problem?
Jul 15, 2010 at 12:33 PM
