1995 Saturn SL2 transmission shifting problems
1995 SATURN SL2
153,000 MILES • 4 CYL • FWD • AUTOMATIC
JONKW8
when i'm driving at low rpm's it seems like the car has a hard time deciding when to shift into the next gear... this mostly happens in 2nd and 3rd gear, with the car hanging a little between gears. (if it were a manual, it feels exactly like letting the pedal off too slow)
is it possible to repair this myself? what's wrong?
Apr 2, 2009 at 10:19 PM
2CARPRO JACK
  • 11,533 POSTS
Start with a service with the correct fluid to see if it will help.Otherwise have the ECM (computer) scanned fo rcodes to see if it has recorded a problem. Some of those Saturn transmissions had issues with the valve body needing to be replaced, but see what the ECM has to say first
Apr 6, 2009 at 8:02 AM
JAMES W.
  • 2,394 POSTS
There's really nothing in your transmission, other than fuid and filter, that's owner servicable. You need to take it in and have the computer scanned and maybe pressure tested to find the problem. Other than that, I'm only guessing and guessing on my part can get expensive on yours. BUT, it sounds like the regulator pressure is low.
Apr 6, 2009 at 8:05 AM
