[quote:3b15a60761="Mark987"]Took some carb cleaning and sprayed all over intake manifold, valve cover hoses, pvc valve, etc. Did not find a leak. Car will run down the road, still doesn't idle without cutting out. Cold start it idles Ok. once it starts warming up, gets worse. Possible EGR valve issue?[/quote:3b15a60761]
ok lets do this since u have a obd1 system and most auto parts stores can only read obd2 for codes heres what i want u to do.on the drivers side bottom of the dash theres the obd1 connector where u would put a code reader on.look at the row of it far right side theres two pins side by side.turn the key to the run postion dont start it and jump those two pins together and leave it that way.watch the service engine soon light flash.u will see it flash once then two faster flashes.thats a code 12 that means the computer is good it will do this 3 times if it repeats the code 12 after the 3 times u dont have any codes.but watch the light for example if u see 3 quick flashes then 2 quick ones that would be a code 32 it would repeat 3 times then go to the next code when it gets back to code 12 then the codes are done.let me know what codes if any u have then we will check out egrs and all that.talk to u soon.
Mar 26, 2010 at 3:07 PM
