1995 Saturn SL2 Checking the Fan
1995 SATURN SL2
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
PSL2
  • 41 POSTS
My car is overheating and I just replaced the thermostat. I think it could be the fan. How could I check if its good or not. Thanks
Dec 19, 2009 at 7:19 PM
BLUELIGHTNIN6
  • 16,542 POSTS
turn the A/C to full blast and the cooling fan should come on automatically. if you don't have A/C then you will have to supply direct 12v to the fan to see if it comes on.
Dec 19, 2009 at 10:18 PM
PSL2
  • 41 POSTS
I turned on the ac and the fan doesn't turn on. Btw I charged my ac. I am just wandering if it's a connector or the fan. How could I tell?
Dec 19, 2009 at 10:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
first check the fuse. if its OK then check the cooling fan relay(s).
Dec 19, 2009 at 11:44 PM
PSL2
  • 41 POSTS
Fuse is good where is the relay??
Dec 19, 2009 at 11:46 PM
BLUELIGHTNIN6
  • 16,542 POSTS
your cooling fan relay is in the engine compartment fuse / relay block.
Dec 20, 2009 at 1:00 PM
PSL2
  • 41 POSTS
O I'll look for the relay. How would I check if it's good?
Dec 20, 2009 at 2:53 PM
BLUELIGHTNIN6
  • 16,542 POSTS
follow this link to learn how to check a relay.. https://www.2carpros.com/how_to/how_do_i_check_a_relay.htm
Dec 20, 2009 at 3:12 PM
PSL2
  • 41 POSTS
Checked the relay and it was good. How would I check the fan if it's good? Thanks for the info
Dec 21, 2009 at 6:26 PM
BLUELIGHTNIN6
  • 16,542 POSTS
will have to supply 12v directly to the fan by running some wire from your battery terminals to the fan
Dec 21, 2009 at 8:10 PM
PSL2
  • 41 POSTS
Cool I'll get right on it
Dec 21, 2009 at 10:17 PM
