1995 Saturn SL2 Car wont turn over
1995 SATURN SL2
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
PSL2
  • 41 POSTS
I have a 95 SL2 and I just fixed the valve cover gasket and replaced the spark plugs and wires however my car wont turn over. Could anyone help me?
Nov 13, 2009 at 11:43 PM
SATURNTECH9
  • 30,869 POSTS
When u say it won't turn off do u mean it cranks but won't start if so does it pop sputter etc?or are u saying it won't even crank over?
Louie
Nov 14, 2009 at 12:33 AM
PSL2
  • 41 POSTS
Yeah I mean it won't crank over
Nov 14, 2009 at 10:06 AM
SATURNTECH9
  • 30,869 POSTS
So what ur saying is when u were done with ur valve cover and spark plug wires u went to start the car and the engine wouldn't turn over?can u hear the starter click no click?do the dash lights come on with the key on?do the dash lights dim or go out when u try to start it.
Nov 14, 2009 at 10:39 AM
PSL2
  • 41 POSTS
That is correct and i was wrong it does turn over but it doesn't start. I think I might not be getting enough spark from the plugs. I'm not sure.
Nov 14, 2009 at 7:10 PM
SATURNTECH9
  • 30,869 POSTS
It sounds like ur spark plug wires might be incorrectly wired when ur looking at the engine starting from ur left that's number one then number two and so on look at ur emissions label it shows which cyclinder goes to which coil post make sure there right let me know what u find.
Louie
Nov 15, 2009 at 1:53 AM
PSL2
  • 41 POSTS
Well at first I put them wrong then I saw how it was supposed to go on the bumper. Also now it isn't starting completely. When I turn the key nothing happens. Thanks
Nov 15, 2009 at 4:20 PM
SATURNTECH9
  • 30,869 POSTS
Well miss placed wires was my best guess did u check to see if u cracked any plugs or if all the plugs were gapped at .040"?if it ran before it's got to be something u did when u made ur repairs.
Louie
Nov 15, 2009 at 6:54 PM
PSL2
  • 41 POSTS
Yeah the spark plugs are gapped at .040 i checked them myself. Now when I try to start it nothing happens. Maybe my starter went bad.
Nov 17, 2009 at 10:32 PM
SATURNTECH9
  • 30,869 POSTS
So now it doesn't turn over?before u said it did can u hear the starter click or anything ?
Louie
Nov 17, 2009 at 11:06 PM
PSL2
  • 41 POSTS
It used to turn over but I guess I tried too many times. It doesn't click or anything. There is no sound when I turn the key. Thanks for the help I really appreciate it.
Nov 18, 2009 at 11:45 AM
PSL2
  • 41 POSTS
Nothing clicks. Its silent as I turn the key. Let me know what you think the problem is. So i can diagnost it.
Nov 19, 2009 at 2:54 PM
SATURNTECH9
  • 30,869 POSTS
well i would make sure the battery cables are clean and tight also u could have just killed the battery try charging it or jump starting it to see if it turns over.
louie
Nov 19, 2009 at 3:52 PM
PSL2
  • 41 POSTS
Thanks for all the help but I got it running with the help of some friends. It was a starter and there was fuel in the pistons so everything is running. Thanks again for taking the time to answer my question
Nov 20, 2009 at 1:07 AM
SATURNTECH9
  • 30,869 POSTS
glad to hear u got it all figured out glad i could help u.
louie
Nov 20, 2009 at 11:54 AM
