1993 Saturn SL2 Please HELP me!!!!
1993 SATURN SL2
175,000 MILES • 4 CYL • 2WD • MANUAL
LUCKIECOWGIRL
  • 14 POSTS
My car is running hot, so far i replaced the thermostat checked the relays and all fuses as well as flushing the radiator.When the car gets hot i noticed the engine cooling fan isn't on-but if i turn on the air conditioner the fan kicks on and immediatly cools the engine the fan stays on until it cycles and shuts off on its own even if i turn off the air but won't come back on when operating temp is reached unless i turn on the air conditioner back on even if just for a min. i was able to pull trouble codes from the PCM which i read to be 26 and 32
from what i found code 26 is a quad driver output fault and i am clueless as to what this.
the other code 32 i found o be the EGR system fault
and i'm not sure where to go from here i was hoping u might be able to help. it would be greatly appreciated !!thank u
Luckiecowgirl
Thanks Jack, i really appreciate it i'll give it a try, and what about the EGR fault???? luckie
Oct 23, 2008 at 2:19 AM
2CARPRO JACK
  • 11,533 POSTS
A bad cooling fan relay can cause thequad driver code. Try swapping the cooling fan relay with another one (a/c, something not vital) and see if it fixes the overheating and the check engine light.You will need to clear the codes first by using a jumper wire to go from terminal "B" to terminal "A" (see pic)with ignition on, touch the wire across those 2 terminals 3 times within 5 seconds and it should clear the codes this connector is located under the dash, drivers side
https://www.2carpros.com/forum/automotive_pictures/1639_saturn_1.jpg
Oct 23, 2008 at 8:01 AM
