My car is running hot, so far i replaced the thermostat checked the relays and all fuses as well as flushing the radiator.When the car gets hot i noticed the engine cooling fan isn't on-but if i turn on the air conditioner the fan kicks on and immediatly cools the engine the fan stays on until it cycles and shuts off on its own even if i turn off the air but won't come back on when operating temp is reached unless i turn on the air conditioner back on even if just for a min. i was able to pull trouble codes from the PCM which i read to be 26 and 32
from what i found code 26 is a quad driver output fault and i am clueless as to what this.
the other code 32 i found o be the EGR system fault
and i'm not sure where to go from here i was hoping u might be able to help. it would be greatly appreciated !!thank u
Luckiecowgirl
Thanks Jack, i really appreciate it i'll give it a try, and what about the EGR fault???? luckie
Luckiecowgirl
Oct 23, 2008 at 2:19 AM
