1993 Saturn SL2 dead but not from battery
1993 SATURN SL2
110,000 MILES • 4 CYL • FWD • AUTOMATIC
BMOSTERD
a few days ago i had to take some things out and put them back in to fix a radiator leak, i know i put everything back together but after this the battery light turned on and i charged it and it ran but i have to do a little bit a drive but when i dropped someone off the car completely died and i got it started went 200 feet and it started to die again and now the engine wont turn over or anything
May 31, 2010 at 2:09 PM
SATURNTECH9
  • 30,869 POSTS
Let's start with this take your battery out and have it charged and tested at the auto parts store.Then if it tests good put it back in your car and make sure your battery cables are clean and tight.Also check all your fuse's. Do you have a multimeter?Let me know when you have done This steps.
May 31, 2010 at 2:29 PM
