I have power at the pink and black wires at the injectors, power on both sides of the connectors (to the injectors). I do not have flash at the dark blue wires while its cranking.
When you unplug the connectors at the injectors the pink/black have power and the blue wire has power. While cranking the dark blue wires are constant power and not pulsing. Should that wires be pulsing a ground signal to control the injector?
The computer or whatever is not working is not controlling the ground side of the injector.
What are the odds that I would have three faulty PCM's currently. Could it be possible and how can I test to see if that is the case? Should I consider buying another PCM to see if it would start?
We plugged a scan tool in and I think the only code that came up was 44 or 45 lean fuel mixture code.
Thanks
Nov 1, 2010 at 12:23 PM
