2002 Saturn SL1 transmission removal
2002 SATURN SL1
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
TERRILUSH
how do you get the transmission out easily?
Mar 21, 2009 at 3:44 PM
BELALZ
Drop the subframe to the get the transmission out the wheel well. 4x18mm bolts.Tranny itself is held by 4 15mm bolts. Also 3 small bolts on the flywheel cover. Disconnect the shifter cables and PULL.
Apr 19, 2009 at 2:12 AM
