depending on the recommended repair procedure i will replace the bearings, bearings and hub (a kit) get a couple of used knuckles out of the wrecking yard with new bearings in them, have the alingment shop do the job and on and on. there is no race to remove. the hub and bearing are separate components, it would be very very rare to have enough corrosion in seattle to cause a problem. this is a 1996 or so thru 2002 saturn sl. i would like the steps say one thru twenty to r&r the front wheel bearings. have you ever replaced the front wheel bearings of a saturn sl? alignment shop says bearings and hubs on both sides would be best. i am not going to take there time and not do business with them. vague information and tools needed information is ok. prefer solid information, pictures, written material describing exact procedure.
Jul 1, 2010 at 4:30 PM
