Engine Cooling problem
2002 Saturn SL1 4 cyl Automatic 130000 miles
I have a coolant leak. I changed the hoses about 2 weeks ago but only after about 500 miles it is leaking again. I do not believe it is the radiator because the leak is "further back"-about tire depth from the front of the vehicle. What could be other sources of the leak? Water Pump, Mainfold, etc. The car does not run hot. I lose maybe 3 or 4 fluid ounces from the overflow resevoir about every 50 miles.
Jul 25, 2010 at 12:07 PM
