2002 Saturn SL1 Brake lights
2002 SATURN SL1
10,500 MILES • 4 CYL • 4WD • AUTOMATIC
BOBBYLANCE
How do you replace the brake light switch, assuming that's the problem. Both brake lights are out and I've changed bulbs and fuses, so I'm left with the switch.
Dec 4, 2009 at 4:24 PM
BLUELIGHTNIN6
  • 16,542 POSTS
is your high-mount (third) brake lamp working good?
Dec 4, 2009 at 10:51 PM
BOBBYLANCE
The high mount lamp is working, but I understand that is on a different mechanism than the rear lamps. Is that incorrect?
Dec 5, 2009 at 9:26 AM
BLUELIGHTNIN6
  • 16,542 POSTS
no, that is correct . it is ran by a separate relay. the brake switch is located under driver dash, mounted on the brake pedal bracket. to replace, disconnect battery. then disconnect electrical connector from switch. unbolt switch from mounting location and replace with new. reconnect electrical connector and battery. test brake lamp operation.
Dec 5, 2009 at 9:28 AM
