[quote:c0f43fe47a="goes2mall"]Air Conditioning problem
1994 Saturn SL1 4 cyl Front Wheel Drive Manual 200000 miles
My a/c went out during the winter sometime, and I bought a recharge kit (it's a retro-fitted R34) and tried to recharge the freon. I evacuated the system, what was left of it anyway, and with the car running and a/c on, tried to recharge but it wouldn't take it. The compressor wasn't running. Any ideas?[/quote:c0f43fe47a]
First of all thank you so much for your donation.Are you sure you have a 1994 saturn you said it's retrofited to R134a they all came factory with R134a.Are you trying to charge it on the hose closest to the exhaust manifold thats the low side thats where you should be charging it.If you have all the hose's hooked up correctly and the can is pierced right then it should charge.The compressor should be off if there isn't any charge in the system.The high low switch shuts off the compressor if there is too little or too much pressure in the system.Lets try this make sure the a/c fuse in your underhood fuse box is good.Then find your high low/ switch which is screwed on your a/c line over by your underhood fuse box.It has two wires going to it with the a/c on unplug the connector you may have to remove a saftey lock on it first.Then jump across the two terminals with a paper clip your a/c compressor should come on with your radiator cooling fan.Don't jump it long just long enough to see if those two items come on.Let me know what you find and the answers to my questions.
Jul 9, 2020 at 1:57 PM
(Merged)
