2000 Saturn SL1 heat selector dont switch
2000 SATURN SL1
74,000 MILES • 4 CYL • FWD • AUTOMATIC
SKIGOR
I have a 2000 Ls1. The heater gets hot and blows, but blows really really lightly. The climate control knob (that directs air to the defrosters, vents, feet, etc...) turns but does not change the air flow. Also, the button that selects fresh or recycled air does not work.
The other controls on that panel (rear defroster, fan speed, etc...) work fine.
Jan 5, 2010 at 10:54 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Mode select cable is binding, bent or need adj. Remove radio to gain access to control panel make sure BLACK cable is attached. Then at heater case see if bent ect. check movement can adjust by removing cable end clip and rotate housing. Hope this helps
Thanks for donate
Jan 6, 2010 at 8:29 AM
