1999 Saturn SL1 powerwindows/ and rearwindow defrost
1999 SATURN SL1
145,000 MILES • 4 CYL • FWD • AUTOMATIC
SCHUMACHER2
all windows quit working at once and at the same time the rear window defroster also quit and the service wrench light also come on this could be for the a/c that needs recharging Thank You.
Jan 8, 2010 at 12:20 PM
SATURNTECH9
  • 30,869 POSTS
theres a fuse they both share in the inside fuse box its the ign3 make sure it has power on both sides of it.also in the under hood fuse box check the power convince 30 amp fuse and rear defogger 30 amp fuse make sure there good and have power to both sides.u can swap the window relay in the inside fuse with another relay thats the same.also on the rear defogger on the drivers side behind the foward kick panel theres a chime module unplug that and plug it back in that fixes the defrosters alot of the time.its the big box retangler shaped cant miss it.try those things let me know what u find.
Jan 8, 2010 at 8:20 PM
