1999 Saturn SL1 Exterior Bulb Socket
1999 SATURN SL1
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
NOREENLM
  • 4 POSTS
How do I take out the exterior brake light socket so I replace it? Can't figure out how to dismantle the wiring to it.
May 30, 2010 at 7:52 PM
SATURNTECH9
  • 30,869 POSTS
[quote:272832eee2="noreenlm"]Electrical problem
1999 Saturn SL1 4 cyl Two Wheel Drive Automatic 90000 miles
How do I take out the exterior brake light socket so I replace it? Can't figure out how to dismantle the wiring to it.[/quote:272832eee2]
If your trying to get the tail light assembley out all you have to do is open the trunk remove all the screws holding it in which are T-15 torx.Then remove the tail light assembley then the sockets just twist out of the housing.Let me know if you have anymore questions.
May 30, 2010 at 8:21 PM
NOREENLM
  • 4 POSTS
Thanks, I will give it a shot and let you know. I tried previously to pull out the assembly (socket) to no avail. I will try twisting like you suggest. If that works I will gladly make a donation. Now I am going back to your site to ask another question about my other car. Thanks.
May 30, 2010 at 11:12 PM
SATURNTECH9
  • 30,869 POSTS
Thanks alot for your donation and thank you for using 2carpros.
Jun 1, 2010 at 10:59 AM
