1999 Saturn SL1 Engine Misfire
1999 SATURN SL1
105,000 MILES • 4 CYL • 2WD • AUTOMATIC
SARATHYR
The Engine is misfiring. The Service Engine light is on. I took it to a mechanic. It shows up as Cylinder.
I have new Spark Plugs and Wires. I am worried if I would connected the wires to wrong points in the Ignition coil. At the Ignition Coil I have 4 1 2 3. Is this correct order for Saturn SL 1
Sep 15, 2010 at 6:37 PM
https://www.2carpros.com/forum/automotive_pictures/12900_f_16.jpg
Sep 15, 2010 at 6:51 PM
SARATHYR
From the Service Engine light on codes this is what was diagnosed. I need to know if they are all inter related:
1) P0301 - Cylinder 1 Misfire detected
2)P0341 - Camshaft Position Sensor A Circuit Range/Performance
3) P0507 - Idle Control System RPM Higher than expected
Sep 16, 2010 at 11:19 AM
