COOLING FAN NOT RUNNING
1999 SATURN SL1
118,000 MILES • 4 CYL • FWD • AUTOMATIC
CHARLIEHACKIT
I checked the cooling fan relay and it's working.I changed the cooling fan sensor but the motor still doesn't come on.Do I need to replace the fan motor or could it be someting else?I also checked the green 30amp fuse for the cooling fan and it was fine.
Oct 13, 2009 at 3:06 PM
SATURNTECH9
  • 30,869 POSTS
if u changed the temp sensor and checked the relay did u make sure that the big green fuse was good in the underhood junction box ?also if ur a/c works turn it on see if ur fan comes on if it does then u have a differnt problem other then a bad motor if it doesnt come on with the a/c tap on the fan motor gentley see if it will start spining while tapping with the a/c on and the a/c compressor clutch spinnig if it comes on after tapping on it bad motor.if it doesnt come on with the a/c working then u need to check for power and ground at the fan motor connector.let me knowwhat u find.
louie
Jan 2, 2020 at 7:58 PM
