1996 Saturn SL1 installing front brakes
1996 SATURN SL1
100,000 MILES • 4 CYL • FWD • AUTOMATIC
DLHOLLEN
How do iget the brake pads onto the calipeer to install the front brakes?
Oct 7, 2009 at 1:40 PM
SATURNTECH9
  • 30,869 POSTS
you remove the bottom caliper pin which is a 14mm head then flip up the caliper.also you have to compress the caliper pistion replace the pads put the pins back in make sure you put the brake pedal back up before you start the car.
louie
Oct 7, 2009 at 1:55 PM
