hello. can you tell me how to install a ignition switch on my 95 saturn. thank you
Mar 7, 2010 at 8:13 PM
SATURNTECH9
CERTIFIED EXPERT
Let me ask u this why are u replacing the ignition switch iam only asking because for the average do it urself it's not that easy u have to drop down the steering column and all that.if it doesn't have to be replaced and it's something else wrong with the car I would hate to see u go thru all that for nothing.let me know.
Mar 7, 2010 at 9:54 PM
HUBBY
MEMBER
hello.the key on the ignition only goes in just the tip, but it does not go in all the way, i play with it saveral times but it does not go in all the way, at times it goes in all the way and it starts, but then i take the key out , and try again, but its the same problem. maybe if i can put a new switch with keys. thanks
Mar 7, 2010 at 10:20 PM
SATURNTECH9
CERTIFIED EXPERT
That's ur cyclinder u said switch ur right for wanting to replace it there alot easier then switch.get a 5.5mm nut driver there's 2 screws on the bottom of the column covers then u can take the top cover off.then uplug the plugs above the cyclinder put the key in the acc postion u will find a square butto push it pull the cyclinder out.u put the cyclinder back in reverse order.if u have anymore questions let me know.
