engine will not produce heat. installed new t-stat and new coolant and at an idle guage will get just below 1/2 way and blow heat, moving down the road air from the heater core is cold and temp guage drops all the way down. the drive to work is about 45min. and all hoses under hood are ice cold. I even tried removing the fan relay to disable the fans, this did not help. Any ideas?
Feb 4, 2009 at 7:59 AM
