1994 Saturn SL1 My Saturn sputters,exhaust sucks slightly,n
1994 SATURN SL1
99,917 MILES • 4 CYL • FWD • AUTOMATIC
TTROXTELL
  • 4 POSTS
Hi guys thanks for looking. I bought the car four days ago and it sounded fine then it began sputtering I replaced the plugs and wires no help. The car sputters, no power when given gas and the exhaust seems to have a vacuum. I would love some help.
Aug 13, 2010 at 2:11 PM
SATURNTECH9
  • 30,869 POSTS
I know this seems like a strange question but what position does the cooling fan turn on the temp gauge?
Aug 13, 2010 at 2:23 PM
TTROXTELL
  • 4 POSTS
So I took off the air cleaner and found the injector was spitting and popping badly on acceleration or at high idle. Could the fuel injector cause the hole problem?
Aug 13, 2010 at 3:23 PM
SATURNTECH9
  • 30,869 POSTS
You have to think also do you have a enough fuel pressure?So the injector get's your engine the correct amount of fuel.Do you have any code's also what mark on the gauge does your cooling fan turn on?
Aug 13, 2010 at 3:26 PM
TTROXTELL
  • 4 POSTS
and the fuel pressure would be the fuel pump? idk where the fan kick on. It's when you give it gas or it turns to high idle that it has a problem. I removed the injector to see if it was grimy and now the car won't start the injector had a torn bottom ring
Aug 14, 2010 at 11:50 AM
TTROXTELL
  • 4 POSTS
replaced the injector and I'm right back where I started. How do I check the fuel getting to the injector? it starts then at idle the fuel injector spits at regular intervals
Aug 14, 2010 at 2:49 PM
SATURNTECH9
  • 30,869 POSTS
https://www.2carpros.com/forum/automotive_pictures/416332_1993_SL1_coolant_temp_sensor_2.jpg
You can rent a fuel pressure gauge at auto zone to see what your pressure is.There is a cap on the threaded port you screw the hose from the pressure gauge to that then start the car and see what the pressure is.The port is on the line going up to your throttle body.I would also see if your fuel filter is clogged or restricted.You could also have a plugged cat.Have you replaced your coolant temp sensor yet?Also inspect the connector to the coolant temp sensor if it's corroded then replace the connector too.There only 10 make sure you get a brass tipped one the plastic tipped one's crack.It's the bottom sensor with two wire's going to it make sure the engine is cold and you will loose coolant.
Aug 14, 2010 at 4:35 PM
