1994 Saturn SL1 motor surges
1994 SATURN SL1
SCOTTRICHTER58
Engine Performance problem
1994 Saturn SL1 4 cyl Two Wheel Drive Automatic
the motor will start hard at first start, and it is just fine after warming up. once the motor has been warmed up for about 20 min. the engine will start just fine.
while after that the motor surges (Spits and putter) at the 35 mph.
when looking down the throttle body of the carb with the motor running, revening the engine, I have noticed that as the gas in being injected with gas you can see the flow of gas shutting on and off. it will backfire once in a while doing this.
Dec 20, 2009 at 12:25 AM
If you can actually see the fuel turning on and off, chances are you have a bad or plugged injector. Have you tried using an injector cleaner? If that doesn't help, check the injector to make sure it is getting constant power. If it is, the injector needs replaced. Also, has the check engine light come on?
Dec 20, 2009 at 11:15 PM
