1994 saturn sl1 4cyl car won't crank, turns over good,firing good.Mechanic said fuel pump bad,changed it and still won't crank.Mechanic had surgery and I've got it back. I found the voltage to the fuel pump goes to 12v at start for about 10 or 15 seconds then drops to about 2v. I swapped the pump relay with another but did the same thing.
Any suggestions would be appreciated.
Jul 11, 2010 at 5:40 AM
