To make a long story shorter, All has been tested from the PCM to the pump. If the PCM is unplugged and I put 12 volts to the signal wire (green w/ white stripe) the fuel pump will run. When the PCM is plugged in, there is no voltage on that wire with the ignition on. I have tried two other PCM's. They all did the same. Is there something else that could possibly be telling the PCM not to turn on the fuel pump? I dont have much hair left, and this has stummed a former saturn mechanic.
Feb 25, 2009 at 6:49 PM
