Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Saturn
SL1
Engine
Symptoms
Stall at Idle
1993 Saturn SL1 ENGINE STALLS WHEN APPLYING THE BRAKE
1993 SATURN SL1
169,000 MILES • 4 CYL • FWD • AUTOMATIC
PROBLEM-SOLVER
MEMBER
FOLLOW
THE ENGINE STALLS WHEN I APPLY THE BRAKE. I HAVE CHECKED THE BOOSTER AND THE VACCUM LINES.
Jul 5, 2010 at 1:55 PM
SATURNTECH9
CERTIFIED EXPERT
Is the only time it stalls is when you apply the brake?Also have you checked the alternator and battery?Have you checked the car for codes?
Jul 5, 2010 at 2:00 PM
PROBLEM-SOLVER
MEMBER
Yes, the only time it stalls is when i apply the brake. The battery and alternator is fine. The car starts easily and idles fine.
Jul 5, 2010 at 2:14 PM
SATURNTECH9
CERTIFIED EXPERT
How did you check the vacuum booster?Did you use a vacuum pump?
Jul 6, 2010 at 11:25 PM
