changing the thermostate on that is easy.when its cold drain the coolant.then follow the lower radiator hose to the engine block that is the thermostate housing.theres two 10mm bolts holding it on take those out.u have to push down and twist to remove the old thermostate.the new one should come with a card board tube to remove and install the new one.let me know how it goes.
Jan 27, 2010 at 2:00 PM
