1992 Saturn SL1 Engie Light Is On
1992 SATURN SL1
RILEY-2010
  • 5 POSTS
Engine Mechanical problem
1992 Saturn SL1 4 cyl Automatic
I am trying to figure out what is a code 12,engie light is on and don't know why.
May 21, 2010 at 9:32 PM
BLUELIGHTNIN6
  • 16,542 POSTS
code 12: No RPM Reference Pulse
This code is normal when no reference pulses are received by control module, such as when the engine is not running
Is the vehicle running poorly? Any other codes stored?
May 21, 2010 at 9:36 PM
RILEY-2010
  • 5 POSTS
The car jerks when it goes up to high speed, the engie was not running at the time code came up. The code was confirmed by a mechanic (friend of ours) which got the code by counting how many flashes there was. No other codes came up.
May 22, 2010 at 12:17 AM
BLUELIGHTNIN6
  • 16,542 POSTS
How does it jerk? In the same gear or while shifting to go up the hill? that code doesn't mean nothing so just ignore it..
May 22, 2010 at 12:19 AM
RILEY-2010
  • 5 POSTS
It's not a stick, it's a automatic.Not to be rude.
May 22, 2010 at 12:31 AM
BLUELIGHTNIN6
  • 16,542 POSTS
i know..it still should downshift when going uphill though..
RILEY-2010
  • 5 POSTS
my car lightly jerks and drags when in gear while driving in especially going into high speeds
May 22, 2010 at 12:39 AM
BLUELIGHTNIN6
  • 16,542 POSTS
when was last time spark plugs and wires were replaced? seems like may have slight misfire issue.
May 22, 2010 at 12:44 AM
RILEY-2010
  • 5 POSTS
actually i just got the car so dont know much about it. I had a mechanic look at it and one of the things he said was that misfiring might be an issues, so a tuneup should clear it up right?
May 22, 2010 at 12:57 AM
BLUELIGHTNIN6
  • 16,542 POSTS
tune up is definitely good place to start and probably will clear it up
May 22, 2010 at 12:28 PM
