1992 Saturn SL1
I believe that's the one saturntech9. It's hollow & the "T" end has the busching in the center (bolts to the chassis). The other end goes through another busching and bolted to the rear wheel assembly. With this damaged the tire moves back & forth as does the rear shock / strut. I will take a picture when the sun comes up but based on your diagram I believe that's the part. Thank you so much...
Jul 12, 2010 at 3:37 AM
