2008 Saturn Sky LIGHT BULBS
2008 SATURN SKY
JDPRIL20
  • 5 POSTS
Electrical problem
2008 Saturn Sky 4 cyl Two Wheel Drive Automatic
LEFT REAR TURN SIGNAL HAS TWO BULBS THAT FLASH WHEN TURNING .ONE IS BURNED OUT. BUT I CANT FIGURE OUT HOW TO TAKE THE HOUSING APART TO CHANGE IT
Sep 6, 2008 at 12:28 PM
KHLOW2008
  • 41,814 POSTS
Hi JDPRIL20, Thank you for the donation. You need to remove the taillamp assy to replace the bulbs.
https://www.2carpros.com/forum/automotive_pictures/192750_TaillampSaturn07Sky_1.jpg
TAIL LAMP REPLACEMENT Preliminary Procedure: Open the rear compartment lid in order to access the tail lamp screws. 1 Tail Lamp Assembly Screws (Qty: 2) Tighten: 2.5 N.m (22 lb in) 2 Chassis Electrical Connector Tip: Lift the tail lamp in order to disengage the retainer clips then disconnect the electrical connector. 3 Tail Lamp Assembly Tip: Transfer the bulb into the new tail lamp. 4 Quarter Filler Panel Nuts (Qty: 2) Tip: Ensure the quarter filler panel nuts are not damaged. Replace if damaged.
https://www.2carpros.com/forum/automotive_pictures/192750_TaillampSaturn07Sky02_1.jpg
TAIL LAMP BULB REPLACEMENT 1 Stop, Tail and Turn Signal Bulb Socket Harness 2 Stop, Tail and Turn Signal Bulb Tip: Pull the bulb straight from the socket in order to remove. 3 Stop, Tail and Turn Signal Bulb Socket Harness 4 Stop, Tail and Turn Signal Bulb Tip: Pull the bulb straight from the socket in order to remove. 5 Rear Side Marker Lamp Bulb Harness 6 Rear Side Marker Lamp Bulb Tip: Pull the bulb straight from the socket in order to remove. Page 1 of 1 LIGHTING -2007 Saturn Sky 9/7/2008
Sep 7, 2008 at 7:21 AM
