1998 Saturn Sedan idling
1998 SATURN SEDAN
160,000 MILES • 4 CYL • FWD • AUTOMATIC
RGRAVES24
The vehicle started idling at a very high rpm, so high that you have to press hard on the brake to keep the vehicle from pulling off when put in drive.
Jan 21, 2010 at 2:06 PM
TOOOMANYTOYS
  • 513 POSTS
Remove the air intake duct from throttle body insure that the throttle plate closes all the way. If that is ok remove the idle air control solenoid and make sure nothing is lodged inside of it. If that does not help look for vacuum leaks.
Jan 21, 2010 at 2:14 PM
