So I was wondering what could be wrong with my car. It seems to run rough at 2 different RPMs. The car starts up fine but when it warms up and the RPMs drop to around 1100-1200 it starts running rough. Then it gets better and when it completely warms up and at idle it runs rough, around 500-700 RRM. When you turn on the Air Conditioner it seems to make the problem much better, you can still feel a little "chugging" sometimes but not nearly as bad. I had the oil, spark plugs, air filter changed and that hasn't made much of an impact. It drives well after it warms up, on the highway and city streets just as long as the RPMs dont drop and it still has pretty good power when you do accelerate from idle. Thanks for you help! Any info will be very helpful. Thanks
Oct 23, 2008 at 8:19 AM
